kunalraiker
May 13, 2012Aspirant
HELP....NEW NOVICE USER SPEED ISSUES READYNAS DUO
Hi, I'am getting average 2 MB/S transfer rate, the Access point used is linksys WAP54G ( with latest firmware) and modem is Tenda 840R ( did update the firmware once, probably on updated firmware)....
May 15, 2012Guru - Experienced User
kunalraiker wrote: I will be using a squuezebox touch that is capable of only 802.11G should should I use 1 channel (2.4 Ghz) at G +N and the other 5Ghz at N for the rest of my laptops and other devices.
Your squeezebox can run 802.11g, while your laptops are running 802.11n - even if they are using the same radio channel.
So try both 2.4 ghz and 5 ghz with the newer devices, and see which works best.
-some clients only run at 2.4 ghz, so you might want to check to see that your laptops actually use 802.11n at 5 Ghz.
-The 5 Ghz band usually has less interference and offers higher speeds, and but also has shorter range. Since your router is two floors below your laptops, you might get better speeds with 2.4 ghz.
