montybiggleswor
Mar 02, 2015Aspirant
HELP! Ripping DVDs to RN104 then stream to Amazon Fire TV?
I would like to copy my 300 or so DVDs to my RN104 then be able to watch them on my Amazon Fire TV, both are connected via 100Mbps Ethernet. I have a 104" screen and a Hi-Fi based 5 channel surrou...
Mar 03, 2015Guru - Experienced User
I don't believe the WDTV Live supports Amazon Prime. At least I am not seeing this on their forum or their user manual.
You could certainly use the WDTV to play MKVs, and the Fire TV to play Amazon Prime and Netflix. It supports both SMB access and DLNA, so you have some options there. SMB access is what I'd suggest, but I'm not really into displaying the cover art - I'm perfectly ok with a list of file names.
