human102
Oct 08, 2015Guide
*HELP* updated my readynas 102 to firmware 6.4.0 today and System Clock is wrong
My system clock defaults to 1969 after updating to 6.4.0 When changing date back to today's date hitting the apply button resets to 1969 again. Oh no... Now what?
Is your NAS connected to your router (and able to access the internet)? What time servers do you see if you click on the settings wheel next to the time on the home page?
You could try changing the first server name to "0.pool.ntp.org" and see if that changes the symptoms.
- joalmojuAspirant
I have the same problem, did you solved it?
it start on 1970 year, if I try to change it manually When it reach 1982 it return to 1970... Weird
- gclynAspirant
Same thing...when I try to change time and hit apply, the change does not work and defaults back to December 1969...the boxes for the time servers are blank, when I input them in and hit apply...no change, they stay blank
- gclynAspirantMy DNS is there....still unable to change date and time
- gclynAspirantIt's blank....when I try to put a server in, then hit apply, it does not save the change. If I go manual, same thing, it will not apply my change
Perhaps contact support.
