curtisw
Jul 30, 2016Follower
Help with file premissions
Hi everyone, I want to set permission for users to access the file share. When I select Shares-->Sare Listing --> CIFS --> Share Access Restrictions section: The check box of Write-enabled user...
Jul 30, 2016Guru - Experienced User
What NAS do you have, and what firmware are you running?
Mine appears grey when I reset the share default access to "disabled", but I can check the box for write-enabled anyway, and then enter information.
There are some guides on setting up permissions - here's an old one that might be helpful: http://www.pinnacleservices.com.au/wp-content/uploads/2012/11/How-to-set-up-your-ReadyNAS-for-Individual-user-based-control-over-shares.pdf
JennC
Jul 30, 2016NETGEAR Employee Retired
Hello curtisw,
Maybe your default access is set to Read/Write where you do not need to enter any users in the Write-enabled users field and groups for group -enabled groups field).
You might want to see also this KB article: How to set ReadyNAS Share Access (RAIDiator 4.x)
Welcome to the community!
