curtisw
Jul 30, 2016Follower
Help with file premissions
Hi everyone, I want to set permission for users to access the file share. When I select Shares-->Sare Listing --> CIFS --> Share Access Restrictions section: The check box of Write-enabled user...
Jul 30, 2016Guru - Experienced User
What NAS do you have, and what firmware are you running?
Mine appears grey when I reset the share default access to "disabled", but I can check the box for write-enabled anyway, and then enter information.
There are some guides on setting up permissions - here's an old one that might be helpful: http://www.pinnacleservices.com.au/wp-content/uploads/2012/11/How-to-set-up-your-ReadyNAS-for-Individual-user-based-control-over-shares.pdf
JennC
Aug 02, 2016NETGEAR Employee Retired
Hello curtisw,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
