Pistolpete11's avatar
Pistolpete11
Help with SECURE access
Help please - in simple steps. I have tried reading a lot of the forum points, but they don't address the issues in full for me.
I have been reading on the BBC website about how they reckon people have too open access to NAS and to lock it down. I can't go to the extreme they suggest of only internal access, but I would like to be more secure. I have tried messing about with the settings but this has led to a mish mash of results.
My needs:-
1. Access the NAS (read/write) from two PC's, an iPad and an iPhone within the house.
- when I switched off Guest or Anonymous, I hit issues as it appears to be inconsistent if it asks for a User. Also, when I put guest back in, I now cannot write (edit) Music tracks
on my NAS from iTunes). Do I need to allow access to CIFS and FTP and/or others?
2. Away from the home, I want to be able to access my NAS from my iPhone, my iPad and my Work Laptop - but restrict it so that only these machines or named users
can do this - I seemd to get this to work on my Work PC and iPad but the iPhone didn't like it. However, this didn't work on my Home PC as said above.
3. ReadyNAS Vault still needs it's access for continual backup.
4. Basically - I want to be able to do this without opening up more that I have to or username/password protecting.
I am on an older NAs (ReadyNAS Duo V2 - I think it is SPARC) so using RAIDiator 4.1.13
Please don't just say you need to configyure X on Y as I may need the instruction on how to configure or where to find that.
My PC is Win XP (yes, I now), my Work Laptop is Win 7. I also connect with a Win 8 laptop for backing up
  • In terms of 'net use' I think the problem is not using the correct Nasname. I've tried everything I could find - is there a definitive place to take it from
  • The work PC had the same issue - I think. As I didn't have the LAN bit working I didn't try too hard. Will try that when I am back in tomorrow
  • StephenB's avatar
    It should be the name you configured in network interfaces (global settings).
    You precede that name with a \\.
  • That is the main one I tried, with no joy. As that side is working maybe best to forget about it and concentrate onRemote & Vault.
  • Update:
    I have tried Remote at work on my Work PC and my iPhone.
    The iPhone is as it was at home - it seems to sign on OK, but doesn't show any shared folders or files
    My Work PC allows me to log in and brings up the NAS in Explorer. When I double click on that it asks for a Username and Password (on my Work domain). I tried adding in the details on Credential Manager with no effect.
    I seem to recall that people only got this working by making one of the access tools e.g. CIFS or AFP or FTP to be guest or anonymous. It would not be good if this is the case but I can't see what else to change.
  • StephenB's avatar
    I think your issue is because Remote's usernames don't exist on the NAS. (That is assuming the username you are using is in the Remote "allowed" list). OS6 is a bit different than OS4 on this, perhaps an OS4 remote user will chime in.
    Your other option is to use FTPS - which uses an encrypted connection. GoodReader supports it on the iDevices, and FileZilla (among other clients) support it on the PC. This is how I access my files remotely.
    You do need to forward about 5 ports to the NAS (one for the control connection, the rest for passive ports). The duo has no option in the GUI to force FTPS, so it will accept normal unencrypted FTP connections. However, if you use FTPS in all your devices, your username/password will not be observable over the network, so if you have a strong password (for both admin and your username) you would still be quite secure. You'd also want a ddns name (noip still offers free ones).
    Though many home users are fine with anonymous/guest access on their local LAN, since they are depending on their router and WiFi security (taking a hard edges/soft center approach to security). You were pretty clear that you didn't want that, but it is a viable option if you aren't sharing your network with others.
  • OK, I get that. So I could use guest/anonymous and it will probably work - but I am talking of outside my LAN so I would be opening up the security if I use it. I might try going to guest just to see if it works and then turn it off and investigate alternatives. Yours is one, and I've also just found out about Readycloud, so I'll look and see if that works. I do have ReadyNAS Vault (assuming it is still working) but and I can acces that, but I found Remote much faster and gives me better access.
    Thank you very much for you help - it has got my LAN part working and I am clear on this.
  • StephenB's avatar
    The new ReadyCloud stuff is OS6 only.
    As far as enabling guest/anonymous goes, if you are using ReadyNAS remote, you still need to log in with the correct username/password. If that is the only way you are accessing the NAS remotely, then it remains secure as long as the ReadyNAS Remote username/password is not compromised.
    Local access would be open, but that is only an issue if (a) there are other users on the LAN that you don't want accessing the share or (b) if your router/wifi security were compromised.
  • Ah! the problems of modern technology - within no time at all you are left behind as new versions and new features are not backward compatible even though the kit works fine. I hate to throw away good kit be it my NAS V1 or my iPhone 4 (now sidelined by iOS8).
    I'll just have to soldier on.
ProSupport for Business
