ricko1
Dec 15, 2014Aspirant
Help with Services
Hi I have been struggling for quite a while with my Duo, hope someone can help! The Duo is showing 0 MB (0%) of 0 MB used , but I can see my shares, with quite a lot of data on the disks . when howev...
RX
Dec 15, 2014Luminary
Since OS reinstall did not help and since you have a backup of all of your data, I suggest you to just factory reset your NAS then restore back the data in it.
