nextwavepc
May 10, 2019Guide
hidden snapshots wont delete
i am showing 1.36TB of snapshots - i only had them enabled on a directory with 200mb shared. i have tried to delete using the ssh to upgrade the snapshot - but no dice. i am running current firmware ...
May 10, 2019Guru - Experienced User
Do you see the snapshots (via ssh) when you enter
# btrfs subvolume list /data
(use your actual volume name instead of /data if you are using flexraid)
If you can see them, then you could try manually deleting them with
# btrfs subvolume delete /path
using the full path of the snapshot (something like /data/sharename/.snapshots/xx/snapshot). Make sure you include the volume name - the btrfs list command doesn't include it.
If the deletion works, you likely will need to do a balance (and maybe a scrub after that) to reclaim the space.
nextwavepc
May 10, 2019Guide
this is what i get when i attempt that command
Using username "root".
[email protected]'s password:
Welcome to ReadyNASOS 6.10.0
Last login: Fri May 10 10:09:25 2019 from tech-1
root@NWNAS:~# btrfs subvolume list /data
ERROR: not a btrfs filesystem: /data
ERROR: can't access '/data'
root@NWNAS:~# root@NWNAS:~# btrfs subvolume list /data
-bash: root@NWNAS:~#: command not found
root@NWNAS:~# ERROR: not a btrfs filesystem: /data
-bash: ERROR:: command not found
root@NWNAS:~# ERROR: can't access '/data'
- StephenBMay 10, 2019Guru - Experienced User
What is the name of your data volume (look on the volume tab of the web ui)?
- nextwavepcMay 10, 2019Guide
ok, so its named RAID so i rerun the command and get.
ID 1491 gen 20856 top level 262 path ._share/test/.snapshot/c_1425099615
ID 1521 gen 22902 top level 262 path ._share/test/.snapshot/c_1427774440
ID 1551 gen 24893 top level 262 path ._share/test/.snapshot/c_1430366434
ID 1582 gen 63461 top level 262 path ._share/test/.snapshot/c_1433044814
ID 1612 gen 63455 top level 262 path ._share/test/.snapshot/c_1435636844how would i structure the delete command?
i reran with the command - volume name is RAID
now i get this...
ID 1612 gen 63455 top level 262 path ._share/test/.snapshot/c_1435636844what is the correct structure of
to delete the snapshots?
RAID
i now get this on the output
ID 1682 gen 63449 top level 262 path ._share/test/.snapshot/c_1441684838
ID 1683 gen 63449 top level 262 path ._share/test/.snapshot/c_1441771243
ID 1684 gen 63449 top level 262 path ._share/test/.snapshot/c_1441857648
ID 1685 gen 63449 top level 262 path ._share/test/.snapshot/c_1441944053
ID 1686 gen 63449 top level 262 path ._share/test/.snapshot/c_1442030458
ID 1687 gen 63449 top level 262 path ._share/test/.snapshot/c_1442116803
ID 1688 gen 63449 top level 262 path ._share/test/.snapshot/c_1442203209
ID 1689 gen 63449 top level 262 path ._share/test/.snapshot/c_1442289613
ID 1690 gen 63449 top level 262 path ._share/test/.snapshot/c_1442376019what is the correct structure to delete?
