russlaw
Oct 10, 2016Aspirant
Home cloud storage like LIMA, but using my readyNAS duo RND2000 v2?
Hi, Someone was telling me about home cloud systems, and I wondered if I can use my readyNAS duo RND2000 v2 to do this? I read about some beta software. I have windows 10 on my laptop, but not on my...
- Oct 10, 2016
russlaw wrote:
ok, V2. would you mind giving me a direct link to the software app, as I just cant seem to find it. thanks
The page you want is here: https://rnxtras.com/addons/owncloud-9-r5arm
"OS 5" is another way we describe the firmware that runs on the v2 NAS (firmware is 5.3.x)
russlaw
Thanks. I need to check the firmware. but If I upgrade it to the latest can I use this new cloud software for readynas I spotted?
Oct 10, 2016Guru - Experienced User
I'm asking about firmware to confirm your NAS model. A lot of v1 owners think they have a v2, because the labels are confusing. Duo v2s run 5.3.x firmware, Duo v1s run 4.1.x firmware.
There is a third-party OwnCloud add-on for both duo models at https://rnxtras.com/ (hosted by WhoCares_ ) There is a small charge. You'll need to make sure you choose the right download for your NAS.
Also, the duo v1 is an old (and by today's standards a slow) NAS. Performance with OwnCloud might not be very good.
- russlawOct 10, 2016Aspirant
ok thanks.. on the bottom it says RDN2000 v2 , but ok , I should plug it in and look into this software.
- StephenBOct 10, 2016Guru - Experienced User
Unfortunately that's the confusing label.
You can also tell from the part number. If the part number ends in -100NAS then it's a v1. A -200NAS is a v2.
