russlaw
Oct 10, 2016Aspirant
Home cloud storage like LIMA, but using my readyNAS duo RND2000 v2?
Hi, Someone was telling me about home cloud systems, and I wondered if I can use my readyNAS duo RND2000 v2 to do this? I read about some beta software. I have windows 10 on my laptop, but not on my...
- Oct 10, 2016
russlaw wrote:
ok, V2. would you mind giving me a direct link to the software app, as I just cant seem to find it. thanks
The page you want is here: https://rnxtras.com/addons/owncloud-9-r5arm
"OS 5" is another way we describe the firmware that runs on the v2 NAS (firmware is 5.3.x)
russlaw
Oct 10, 2016Guru - Experienced User
- russlawOct 11, 2016Aspirant
OK thanks,
So Can I just use this thing called ReadyCLOUD with my current hardware?
- JennCOct 11, 2016NETGEAR Employee Retired
Hello russlaw,
Please try running RAIDar as this will show you the current status of your NAS and its current firmware version.
If the firmware version starts with 5.3 then you are using a ReadyNAS OS5 which is not compatible with ReadyCloud. If it starts with 4.1, you are using ReadyNAS OS4 which is also not compatible with ReadyCloud.
ReadyCloud is only compatible with ReadyNAS OS6. ReadyNAS OS4 and OS5 units are discontinued, they use ReadyNAS Remote that is comparable to ReadyCloud.
- russlawOct 12, 2016Aspirant
Hi, I downloaded raidar 6.1 and ran it. And it shows firmware 4.1.7 Even though it says clearly a V2 on the bottom of my readynas.
Is this firmware updatable? Also, when I click any of the buttons like admin, or locate, it says YOUR NETGEAR STORAGE is not accesable from this computer. Check your network settings.
This was a good way for me to know what I had.
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
