musicfreak
Oct 01, 2012Aspirant
Hope is not a plan... #19636384 [CLOSED]
Hello, I will try my best to remove all emotion from this post/question/plea for help :D Purchased a new ReadyNas NV+ mid-2007 and until mid-2012 it ran without an issue (save replacing one drive...
mdgm-ntgr
Oct 01, 2012NETGEAR Employee Retired
You could try opening a support case at my.netgear.com but if the unit was purchased before August 21, 2007 it would be out of warranty. Also any damage caused by a power surge etc. wouldn't be covered by warranty.
If you can get the NAS to boot can you download the logs (Status > Logs > Download all logs). Any errors in diagnostics.log?
