musicfreak
Oct 01, 2012Aspirant
Hope is not a plan... #19636384 [CLOSED]
Hello, I will try my best to remove all emotion from this post/question/plea for help :D Purchased a new ReadyNas NV+ mid-2007 and until mid-2012 it ran without an issue (save replacing one drive...
musicfreak
good evening mdgm,
I pulled disc 2 and hard rebooted the system. I was able to download the logs to a .zip file, there does not seem to be any errors in the diagnostics.log:
Disks
Passed diagnostics.
Memory
Passed diagnostics.
Network
* There have been an abnormally high number of unrecoverable TCP retransmits. This is usually caused by marginal hardware somewhere on the network, including cable, switch, and network interfaces.
Performance
* Journaling is enabled on the NAS filesystem. This is the recommended setting when you do not have a UPS. For optimal performance, you can attach a UPS to the system and disable journaling in the System -> Performance tab.
* Jumbo frames are disabled on interface 1. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
Volume
Passed diagnostics.
Disks
Passed diagnostics.
Memory
Passed diagnostics.
Network
Performance
Volume
Passed diagnostics.
