musicfreak
Oct 01, 2012Aspirant
Hope is not a plan... #19636384 [CLOSED]
Hello, I will try my best to remove all emotion from this post/question/plea for help :D Purchased a new ReadyNas NV+ mid-2007 and until mid-2012 it ran without an issue (save replacing one drive...
mdgm-ntgr
Oct 17, 2012NETGEAR Employee Retired
They shouldn't need to go in via TeamViewer if the tunnel connection between your NAS and NetGear is working. Given that 5-digit ID they should be able to connect directly to your NAS, not via your PC/Mac.
Debug mode is a low-level diagnostics mode. In this mode the bare minimum of services necessary for remote diagnostics are started. You can't access Frontview and while you can see the unit in RAIDar you can't connect to it via that either. No harm in opening RAIDar though. You'd see the 5 digit ID in the far right (Info) column.
