musicfreak
Oct 01, 2012Aspirant
Hope is not a plan... #19636384 [CLOSED]
Hello, I will try my best to remove all emotion from this post/question/plea for help :D Purchased a new ReadyNas NV+ mid-2007 and until mid-2012 it ran without an issue (save replacing one drive...
Oct 20, 2012Guru - Experienced User
I have never seen them with my NV+
If no one is connecting anything to the front USB port, that the GREEN error sounds like flakey hardware.
The YELLOW error could be a bad backup switch - unless someone is pressing it with no USB connected. If you set up a dummy backup job (that copies a dummy (empty) share to another dummy on the same NAS, you can then configure the backup button to trigger that dummy job instead. A bit of a nuisance though.
Is the unit still under warranty? If so you might contact Netgear support (on-line would still be free).
