JoeJinis
Aug 19, 2017Aspirant
How can I delete invisible snapshots?
Hello there, Model ReadyNas102 v6.80 1*3To My disk shows that it's full : Data 2.00To Snapshots 742.92Gb Freespace 723mb But I deleted and desactivated all the snapshots, when I searh through the...
- Aug 23, 2017
Hello again,
I decided to learn a bit about ssh so I logged on the nas via ssh, and did the command to force upgrade the snapshots to v6.80.
Then it made the snapshots to appear again, then I deleted them and redid a balance.
Snapshot place is now completely free =)
I am happy, issue solved =)
Marty_M
Aug 22, 2017NETGEAR Employee Retired
Hello JoeJinis,
You may perform a Volume Balance on the volume on your NAS and check if it will free up space. Please check the guide here.
Welcome to the community!
Marty_M
NETGEAR Community Team
Marty_M
Aug 23, 2017NETGEAR Employee Retired
Hello JoeJinis,
It does appear performing Volume Balance did not made a difference. Next option would be contact support since the concern may require assistance from the engineers and/or higher tier who can remote in to the NAS and fix this from the backend.
Marty_M
- JoeJinisAug 23, 2017Aspirant
Hello again,
- Marty_MAug 24, 2017NETGEAR Employee Retired
Hello JoeJinis,
It doe s appear that you manage to address the concern from the backend by your own. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team- JoeJinisAug 26, 2017Aspirant
How do I mark as solution? ^^
