chaug
Oct 01, 2016Aspirant
How can I get RAIDiator 4.2 to understand xz compression (in newer .deb packages)?
I would like to install a newer deb package on my ReadyNAS Ultra 2 but it fails because Debian Etch doesn't understand xz compression which the newer deb files use. Is there a way of teaching it how ...
- Oct 03, 2016
To make RAIDiator 4 "understand" xz compressed .deb packages you'd need to backport dpkg in at least version 1.16 and also backport the xz-utils package. However that won't help you much since Duplicati also requires a fairly recent version of the Mono framework. To be able to backport that to RAIDiator you'd next need to backport gcc 4.9 because newer Mono versions use functions that are only provided by gcc 4.9 and newer.
So in essence it would really be easier to upgrade your Ultra to RNOS 6. Should work fine, at least does for me on two boxes I use for developing the kernel modules.
-Stefan
chaug
Hm, I have avoided upgrading do OS6 based on the rule "never change a running system" and because it is not supported which means I fill find myself googling and browsing through this forum in order to get stuff running again. Are you suggesting that OS6 is basically running without problems on the Ultra machines?
I'll mention the package that I'm talking about because it is actually very a very interesting one for many people: http://www.duplicati.com/download
Maybe someone with the necessary skills is willing to adapt it to Debian Etch or create a RAIDiator addon?
WhoCares_
Oct 03, 2016Mentor
-Stefan
