Rynar401
Jan 14, 2012Aspirant
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. F...
Rynar401
1.6 TB's used.. I already started the process of swapping the 1st drive but nothing is working. I removed the old drive from slot 1 and put the new drive in. But Nothing is happening except Frontview is telling me I have a dead drive but the drive its saying is dead is the Western Digital Drive. Also it is acting like I pulled the old drive and never put a new one in. In my log it shows something was started but I have no indication anything is going on now. This is my log...
Sat Jan 14 11:49:29 MST 2012 Data volume will be rebuilt with disk 1.
Sat Jan 14 11:46:39 MST 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 1]
Sat Jan 14 11:43:42 MST 2012 If the failed disk is used in a RAID level 1, 5, or X-RAID volume, please note that volume is now unprotected, and an additional disk failure may render that volume dead. If this disk is a part of a RAID 10 volume,your volume is still protected if more than half of the disks alive. But another failure of disks been marked may render that volume dead. It is recommended that you replace the failed disk as soon as possible to maintain optimal protection of your volume.
Sat Jan 14 11:43:42 MST 2012 Disk failure detected.
Sat Jan 14 11:43:26 MST 2012 A disk was removed from the ReadyNAS.
Sat Jan 14 11:43:26 MST 2012 Disk removal detected. [Disk 1]
My readyNAS sais "C: unprotected"
My RAIDar shows a yellow light.
What do I do now?
and what is the 3a option? Can I still do it?
What do I do now?
