Rynar401
Jan 14, 2012Aspirant
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. F...
Rynar401
Jan 20, 2012Aspirant
I had to log into my readynas and uncheck the disable journaling option under system/performance. Then click apply and reboot the readynas. These instructions should have been given to you in the status logs. If not try it anyways. Once this is done you disable journaling again. For some reason this process has to be done to continue the volume expansion.
