Rynar401
Jan 14, 2012Aspirant
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. F...
mdgm-ntgr
Jan 20, 2012NETGEAR Employee Retired
No. Journaling must be enabled (disable journaling unchecked). Setting for full data journaling doesn't matter.
You will need a fourth 2TB drive installed before the volume will expand
