Rynar401
Jan 14, 2012Aspirant
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. F...
Rynar401
Jan 20, 2012Aspirant
Oh. The reason you are only showing 1tb drive is because your #1 slot drive is only 1tb. This will limit all others to that size. Should look into how to configure it so your smaller drive is in slot #4. I believe that will solve your problem. Or just replace it with a 2 tb would be a better choice. Not sure if swapping the order of your drives is a good idea or if it will effect your data.
