Rynar401
Jan 14, 2012Aspirant
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. F...
mdgm-ntgr
Jan 20, 2012NETGEAR Employee Retired
danmandle wrote: My Ch 1 drive was a 1TB drive. Now there's nothing in Ch 1, and a 2TB drive in channels 2, 3, 4.
Which is one reason why I said you needed a fourth 2TB drive. You cannot reduce the number of disks and get expansion on any ReadyNAS. You'll need to either add a 2TB disk in Ch1 or backup your data and do a factory default (wipes all data, settings, everything).
If you download your logs (Status > Logs > Download all logs) and extract the zip contents what does your partition.log look like?
