Rynar401
Jan 14, 2012Aspirant
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. F...
danmandle
Jan 20, 2012Aspirant
So they're no way to manually change anything so I don't need to buy another drive?
Here's my partition log:
Disk /dev/hdg doesn't contain a valid partition table
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hde1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hde2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hde3 4608032 1953092263 974242116 5 Extended
/dev/hde5 4608040 1953092263 974242112 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
/dev/hdi1 32 4096031 2048000 83 Linux
/dev/hdi2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hdi3 4608032 1953092263 974242116 5 Extended
/dev/hdi5 4608040 1953092263 974242112 8e Linux LVM
Disk /dev/hdc: 999.9 GB, 999991611392 bytes
255 heads, 63 sectors/track, 121575 cylinders, total 1953108616 sectors
/dev/hdc1 32 4096031 2048000 83 Linux
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hdc3 4608032 1953092263 974242116 5 Extended
/dev/hdc5 4608040 1953092263 974242112 8e Linux LVM
