Rynar401
Jan 14, 2012Aspirant
How can I upgrade 4 HDs with 3 HDs?
Ok, so I bought 4 1.5 Terrabyte hard drives with my ReadyNAS NVX pioneer addition server. I was having a lot of disconnect issues and hanging issues as well as very poor performance on the server. F...
mdgm-ntgr
Jan 20, 2012NETGEAR Employee Retired
That partition log looks fine. You have 4k sector alignment which means you last did a factory default on 4.1.7 or later. Disk 3 /dev/hdg is your parity disk that's why it doesn't have a partition table on it.
No. You either have to replace the removed disk (considered to be "dead" by the ReadyNAS) with a 2TB disk, or backup and do a factory default (wipes all data, settings, everything).
