prchrist
Jun 20, 2009Aspirant
How do I get rid of 'Invalid Certificate' Error in IE7?
Hi; very new to this, just got the NV+ this week. Followed the instructions for install and have been getting 'Invalid Certificate' errors in IE7 whenever I access my unit. If I ignore the warning ev...
RydForLyf
Jun 24, 2009Tutor
I had the same problem until I created the cert with the same internet domain name that I was using to access the box. I had previously used the 192.168.1.2 ip address and continued to get the error when accessing the box through my address at dyndns.org. Once I used my dyndns.org domain name to issue the cert, everything was fine.
I hope this helps.
I hope this helps.
- May 04, 2020Retired_Member
