prchrist
Jun 20, 2009Aspirant
How do I get rid of 'Invalid Certificate' Error in IE7?
Hi; very new to this, just got the NV+ this week. Followed the instructions for install and have been getting 'Invalid Certificate' errors in IE7 whenever I access my unit. If I ignore the warning ev...
prchrist
Jun 25, 2009Aspirant
Thanks; got a reply in another forum that suggested the same resolution, and it worked.
Seems simple once you find the answer.
Thanks for your input.
- May 04, 2020Retired_Member
