prchrist
Jun 20, 2009Aspirant
How do I get rid of 'Invalid Certificate' Error in IE7?
Hi; very new to this, just got the NV+ this week. Followed the instructions for install and have been getting 'Invalid Certificate' errors in IE7 whenever I access my unit. If I ignore the warning ev...
StaticFree
Jul 03, 2009Tutor
prchrist wrote: Thanks; got a reply in another forum that suggested the same resolution, and it worked.
Seems simple once you find the answer.
Thanks for your input.
Hello folks, I am a new ReadyNAS DUO user and am having same problem using Windows Vista with IE8. I cannot add the certificate to the trusted certificates zone because when I click on the red certificate error bar and it shows the certificate details, all the options to perform any actions on it are greyed out! All I can do is view the info on the certificate, but nothing I see allows me to click "add" certificate to be trusted. The certificate name is simply the ip address of my ReadyNAS DUO unit. Should I rename and regenerate the certificate with a text name of say my registered dynorg.org hostname? Or is there a way to import the certificate from the ReadyNAS DUO? Where is the generated certificate stored such that I can point IE8 browser there to fetch it and install it into the trusted certificates zone?
- May 04, 2020Retired_Member
