prchrist
Jun 20, 2009Aspirant
How do I get rid of 'Invalid Certificate' Error in IE7?
Hi; very new to this, just got the NV+ this week. Followed the instructions for install and have been getting 'Invalid Certificate' errors in IE7 whenever I access my unit. If I ignore the warning ev...
dbott67
Oct 17, 2009Guide
mld wrote: I can eliminate the "invalid certificate" problem for either local access via 192.168.0.10 or remote access via a.b.c.d, but not BOTH at the same time.
Correct. I do not believe that you can have to valid certificates at the same time.
I think the only way to cure this problem is to use a FQDN and then generate the certificate. There are many dynamic DNS services that you allow you to create a FQDN such as mld.dyndns.com to get your external users connected to your external IP (a.b.c.d). However, internally you may face problems with routing or name resolution. You can cure this by creating an entry in you hosts file that points mld.dyndns.com to 192.168.0.10.
In Windows, edit the C:\Windows\System32\drivers\etc\hosts file and add your dynamic DNS name:
192.168.0.10 mld.dyndns.com
Do this for each of the machines on your internal LAN. Of course, mld.dyndns.com is just an example --- feel free to register whatever name works for you and with whatever DynDNS service is supported by your router. Change the entries accordingly in the hosts file.
-Dave
- May 04, 2020Retired_Member
