prchrist
Jun 20, 2009Aspirant
How do I get rid of 'Invalid Certificate' Error in IE7?
Hi; very new to this, just got the NV+ this week. Followed the instructions for install and have been getting 'Invalid Certificate' errors in IE7 whenever I access my unit. If I ignore the warning ev...
dbott67
Oct 17, 2009Guide
mld wrote:
Windows Media Player cannot play the file because a network error occurred. The server might not be available. Verify that you are connected to the network and that your proxy settings are correct.
Is this internal, external or both?
If external only, it may be some sort of firewall/port-blocking issue with the router. If both internal & external exhibit this behaviour, I'm not sure what the issue is.
I take it you're pointing WMP to the dyndns IP over http. What happens if you just use the internal IP (rather than the FQDN)?
- May 04, 2020Retired_Member
