prchrist
Jun 20, 2009Aspirant
How do I get rid of 'Invalid Certificate' Error in IE7?
Hi; very new to this, just got the NV+ this week. Followed the instructions for install and have been getting 'Invalid Certificate' errors in IE7 whenever I access my unit. If I ignore the warning ev...
CliftonCaldwell
Aug 30, 2011Aspirant
Hi,
I'm running Windows 7 and IE9. I've tried the above steps many times and have not had any luck. It continues to come up with the Certificate error.
I am also unable to access the protected shares. It doesn't appear to recognise the login username and password, yet other computers (running Windows XP) on the same network can access the shares without any problems.
Has anyone else run into this problem.... I'd be glad of any suggestions!!
Thanks
Thanks
- May 04, 2020Retired_Member
