cguers
Aug 11, 2013Aspirant
How do I know when disk rebuild is done?
Hi! I am replacing 2TB disks with 3TB disks on my Ultra 6. How can I be certain that the disk rebuild is done for each disk? I replaced the first disk and I got messages that it detected that I ha...
mdgm-ntgr
Aug 11, 2013NETGEAR Employee Retired
Yes it should have made a status log entry.
If you download the logs (Status > Logs > Download all logs) and extract the zip contents what are the contents of mdstat.log?
