cguers
Aug 11, 2013Aspirant
How do I know when disk rebuild is done?
Hi! I am replacing 2TB disks with 3TB disks on my Ultra 6. How can I be certain that the disk rebuild is done for each disk? I replaced the first disk and I got messages that it detected that I ha...
cguers
Log file partition.log has:
***** partition output for sdd *****
Disk /dev/sdd: 5860533168 sectors, 2.7 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): 502E19AD-F377-43C2-87FD-9F0C29E9E0B5
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 5860533134
Partitions will be aligned on 8-sector boundaries
Total free space is 1953509108 sectors (931.5 GiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00 Linux RAID
2 8388672 9437247 512.0 MiB FD00 Linux RAID
5 9437256 3907024064 1.8 TiB FD00 Linux RAID
Disk /dev/sdd: 364801 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sdd1 0+ - 0- 2147483647+ ee EFI GPT
/dev/sdd2 0 - 0 0 0 Empty
/dev/sdd3 0 - 0 0 0 Empty
/dev/sdd4 0 - 0 0 0 Empty
***** partition output for sdb *****
Disk /dev/sdb: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 7B55C649-F44F-4421-82C1-EFA1AC8CBAB6
First usable sector is 34, last usable sector is 3907029134
Total free space is 5108 sectors (2.5 MiB)
Disk /dev/sdb: 243201 cylinders, 255 heads, 63 sectors/track
/dev/sdb1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdb2 0 - 0 0 0 Empty
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
***** partition output for sdc *****
Disk /dev/sdc: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 708144C3-E85B-492B-A417-915F3CD52C15
Disk /dev/sdc: 243201 cylinders, 255 heads, 63 sectors/track
/dev/sdc1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdc2 0 - 0 0 0 Empty
/dev/sdc3 0 - 0 0 0 Empty
/dev/sdc4 0 - 0 0 0 Empty
