mattebury
Mar 22, 2011Aspirant
How do I see my Time Machine?
OK, I've had my ReadyNAS NV+ for years and basically used it as a file server. I consider myself to be completely naive on the inner workings of both my Mac and my NAS. Now that I've established m...
mdgm-ntgr
Mar 22, 2011NETGEAR Employee Retired
If you have CIFS enabled, I would go to the Finder, select the Go menu, connect to server and connect to "smb://ip.address.of.nas/c/.timemachine". You can then delete the sparsebundle there. It can take hours to delete, so be patient.
You could alternatively increase the limit in Frontview beyond the 500GB limit currently set.
