mattebury
Mar 22, 2011Aspirant
How do I see my Time Machine?
OK, I've had my ReadyNAS NV+ for years and basically used it as a file server. I consider myself to be completely naive on the inner workings of both my Mac and my NAS. Now that I've established m...
mattebury
I'm sure this is painfully obvious, but when I type in the admin and password for Frontview into the dialog box for finder using the Go|Connect to Server (registered user radio button not guest, correct?) I still get the same message. By default, I'm logged into the NAS as "Guest," but I can connect as admin to both CIFS and AFP, however, I do not see the Time Machine Volume in either when logged on, does it take time to show up and I'm being impatient?
