ScottChapman
Dec 10, 2014Apprentice
How does bitrot protection actually work?
I understand the concept, but am curious how it is actually implemented on 6.2.0
Dec 21, 2014Guru - Experienced User
Well, of course the ECC Ram costs more for Netgear to buy, and on top of that you need other system components that support the RAM. The lower end of their market is price sensitive (it always is), so I think from a business point of view it likely isn't viable for them to include ECC there.
snakyjake wrote: After looking at the different models, I don't have a lot of confidence in the cheaper non-ECC models. For a prosumer, it gets quite expensive.
For better or worse, most consumers simply aren't as concerned about silent bit rot as you are, so ECC is not a must-have feature for them. If enterprises started demanding it in all devices, that would likely change - but I haven't seen much that suggests that will happen anytime soon.
That said, I think Netgear should describe what they are doing in more detail.
