winger
Sep 20, 2011Tutor
How does RSYNC "verify" integrity of a backup???
I have performed a factory reset my ReadyNAS Pro Pioneer (RNPP) unit. and now want to ensure the restore of the original data from an external USB drive (connected to the NAS' USB port) is copied with...
mdgm-ntgr
Sep 20, 2011NETGEAR Employee Retired
Oops. I guess I was wrong then. Using file size and timestamp should be sufficient because one of those is slightly off if the file wasn't copied successfully.
