winger
Sep 20, 2011Tutor
How does RSYNC "verify" integrity of a backup???
I have performed a factory reset my ReadyNAS Pro Pioneer (RNPP) unit. and now want to ensure the restore of the original data from an external USB drive (connected to the NAS' USB port) is copied with...
winger
Sep 20, 2011Tutor
mdgm wrote: Oops. I guess I was wrong then. Using file size and timestamp should be sufficient because one of those is slightly off if the file wasn't copied successfully.
LOL, are you sure you are wrong? Again, I have seen BOTH sides of the story.
OK, let me ask this. IS there a definitive way to do the checksums verification natively on the NAS?
I mean, I can use/run FreeFileSync (http://freefilesync.com/) from my network-connected PC to compare the USB version of the file versus that on the RNPP, but that takes ALONG time because of the time it takes to pull data across my network (100 not 1000Mbps) and my PC is OLD (~4+ yrs laptop), so I prefer not to go that route.
