winger
Sep 20, 2011Tutor
How does RSYNC "verify" integrity of a backup???
I have performed a factory reset my ReadyNAS Pro Pioneer (RNPP) unit. and now want to ensure the restore of the original data from an external USB drive (connected to the NAS' USB port) is copied with...
mdgm-ntgr
Sep 20, 2011NETGEAR Employee Retired
Just had a look and there is an option for rsync to compare (to decide which files have changed) by checksum. From reading your quote of ewok's it sounds like this option is not used by Frontview backup jobs.
If you have SSH access you could run rsync manually from the command line with the relevant option specified.
