winger
Sep 20, 2011Tutor
How does RSYNC "verify" integrity of a backup???
I have performed a factory reset my ReadyNAS Pro Pioneer (RNPP) unit. and now want to ensure the restore of the original data from an external USB drive (connected to the NAS' USB port) is copied with...
winger
Sep 23, 2011Tutor
ewok wrote: Rsync, by default, will use the timestamp and filesize to determine if a file has changed. The Backup Manager has no facility to use rsync checksums, but feel free to create a post in the Feature Requests forum.
From the rsync man page:
Rsync finds files that need to be transferred using a "quick check"
algorithm (by default) that looks for files that have changed in size
or in last-modified time.
Thanks for responding, Ewok.
Do you know the answer to my question above (when using the FrontView RSync), which is:
.... Will even the slightest corruption result in a file size difference that can/will be detected by the Rsync process?
For your suggestion on placing a post in the requested features section, will do.
