winger
Sep 20, 2011Tutor
How does RSYNC "verify" integrity of a backup???
I have performed a factory reset my ReadyNAS Pro Pioneer (RNPP) unit. and now want to ensure the restore of the original data from an external USB drive (connected to the NAS' USB port) is copied with...
winger
Sep 23, 2011Tutor
ewok wrote:
TeknoJnky wrote: or run rsync with -c and then it will compare checksums of both source and destination to determine whether to copy the file/delta data.
Of course, that would be a good option, but you'd have to open up the NAS. :)
Guys, so I have SSH enabled now. Is this Rsync with -c option something I can run directly from the NAS using Putty (comparing NAS data versus data on a USB-connected HardDrive) ? If yes:
1) what are the exact commands to run for my setup? Here is one set of folders I would want to compare:
NAS:
Share name = Data01
USB Harddrive:
NAS volume name: USB_HDD_3
Folder: /backups/Data01
2) would running this -c Rsync process produce an output of differences ? or will the Rsync process just copy (from the USB to the NAS) when differences are detected?
