winger
Sep 20, 2011Tutor
How does RSYNC "verify" integrity of a backup???
I have performed a factory reset my ReadyNAS Pro Pioneer (RNPP) unit. and now want to ensure the restore of the original data from an external USB drive (connected to the NAS' USB port) is copied with...
winger
Sep 24, 2011Tutor
TeknoJnky wrote: I have no way to verify if it did or didn't work, but putting --checksum in the rsync exclusion fields didn't cause any errors and in theory would be passed along to the backup job command line
I no files which only differs by a couple of bits, but gave this a test run with a Share that has approx 1.5GB of data (unchanged between source (NAS) and backup target (USB HDD) )
Main difference I see is between the "sent xxxxx bytes" figure
with "--checksum" : 113875
without "checksum" : 113859
Does this tell one way or another if adding the "--checksum" into the "Add files and directories to be excluded as a comma separated list" field (of the backup's Rsync settings) works ?
WITH --CHECKSUM
INCREMENTAL Backup started. Sat Sep 24 10:34:25 PDT 2011
Job: 001
Protocol: rsync
Source: [Datatest]/
Destination: 192.168.0.200::USB_HDD_1/backups/Datatest
sending incremental file list
sent 113875 bytes received 246 bytes 228242.00 bytes/sec
total size is 1529466744 speedup is 13402.15
Backup finished. Sat Sep 24 10:34:25 PDT 2011
WITHOUT --CHECKSUM
INCREMENTAL Backup started. Sat Sep 24 10:33:42 PDT 2011
Job: 001
Protocol: rsync
Source: [Datatest]/
sent 113859 bytes received 246 bytes 228210.00 bytes/sec
total size is 1529466744 speedup is 13404.03
Backup finished. Sat Sep 24 10:33:42 PDT 2011
