vipzz
Jul 18, 2011Follower
How does this sound?
Hi All, Got my ReadyNAS ultra 4 for about 2 weeks now and I must say i'm pretty happy so far :D Just did a couple of read and write tests and thought i'd share them with the community :) At fir...
dbott67
Jul 18, 2011Guide
vipzz wrote: On the read test I now got 116.1MB/s with peaks of over 126.6MB/s
Sweet!
vipzz wrote: on the write tests I got 48MB/s
Performance will always be limited by the slowest bottleneck. As you've found when creating a RAM disk, you can really see that a single non-RAID desktop system has pretty slow disk I/O compared to the ReadyNAS. I suspect that you may be hitting some sort of bottleneck on your Mac Mini. Maybe you need to buy another Utra to test performance! :wink:
I've written an article on some of the factors that come into play when testing performance: http://home.bott.ca/webserver/?p=363
vipzz wrote: Does adding one more disk do anything with the performance? Does it help or hurt it?
More disks = more speed 8) - viewtopic.php?f=21&t=54618#p310625
StephenB wrote: Ok, I now have 4 disks installed, which I added one at a time, waited for the volume expansion to complete, and then tested.
Bonnie (add-on disk diag) reported
1 disk - 59.7 MB/s
2 disks - 110 MB/s
3 disks - 219 MB/s
4 disks - 319 MB/s
So the disk throughput definitely goes up as you add more disks.
However, the iometer speed did not change on my Windows 7 machine. No matter how many drives were installed, I still see 55-60 MB/s of read performance, and 80-83 MB/s of write performance. So there is more investigation needed on that.
- Sep 11, 2022Retired_Member
