MammothJerk
Aug 16, 2013Aspirant
how does this work?
Okay so i bought my RN 104 a while back and slapped 2 3tb wd reds in there in raid 0, now i would like to use it to back up my data in my computer. i started by going to the readynas admin page fo...
mdgm-ntgr
Aug 17, 2013NETGEAR Employee Retired
Have you setup the network permissions for that share correctly? Under the sharing preferences for the I:\ (or whatever the local drive or folder is) there may be advanced options that you should look at.
It sounds like you haven't configured permissions to allow access to that share from any computer other than the PC it resides on. Or you are connecting as a user that is not allowed access. You can see all shares if logged in as the wrong user (this includes guest access) but you can't access shares that you are not given access to.
have you entered login credentials to connect to the network share in the backup job settings?
