howarddavidp
Jan 04, 2016Tutor
How I got Bonding to work with a TP-Link TL-SG3210 switch
Hello, I thought I would share, since I was puzzled how or why this happened to me and the switch I had. In the end, I got everything to work, and I do NOT think it is a NTGR issue, but if someo...
- Jan 04, 2016
You definitely want LACP if you are bonding at the switch.
If you have an unmanaged switch, you can try "adaptive load balancing" on the NAS (with no configuration needed anywhere else).
Jan 04, 2016Guru - Experienced User
howarddavidp
Jan 04, 2016Tutor
The choices were Static LAG or LACP, I guess, but there is little documentation with that switch, so I had to guess.
- BrianL2Jan 05, 2016NETGEAR Employee Retired
Hi howarddavidp,
This post will surely help others who may encounter the same problem. Tag this thread as resolved by clicking "Accept as Solution" in one of the responses that you received.
Kind regards,
BrianL
NETGEAR Community Team - StephenBJan 06, 2016Guru - Experienced User
I agree that the choices are confusing and usually under-documented. You ended up in the right place, and your post will be helpful to others.
Generally the best options with the NAS are LACP (either with a managed switch or an R8500 router), or Adaptive Load Balancing (which works with unmanaged switches). If you don't understand exactly what you are doing, you should simply ignore the other options.
Also, I'd like to point out that the gains for home users aren't very compelling. It's frankly not worth spending a lot of time getting this to work, unless you are in an enterprise environment with lots of users.
- howarddavidpJan 06, 2016Tutor
Hello,
I am in a quasi-home environment, not a typical home, but also not an office environemnt either.
I have over 20 devices that are constantly connected to my LAN, and at least 15 of those are PC's or MAC's. I have evferything backup with Acronis nightly, between 2AM and 6AM, so at this time I do see high utilization and this LACP connection appears to help with that, judging from how much faster the backup jobs complete vs a single GBe connection.
I am looking into doing this myself, but I have always wished there was an Acronis app for ReadyNAS where I could PXE boot into the device and load Acronis for restores when I have a drive fail (via booting over TFTP to an ISO file stored on my NAS). I know I need to setup a TFTP server (which I have seen available for NTGR), and I also think I would need to make the ReadyNAS the DHCP server, or at least be able to modify the existing DHCP server to pass the "bootfile" parameters in the DHCP info (to clients) to make it work. I have it works on a PC, but not yet with my NAS. My ask would be to have an app that does all of this, but the mods to the DHCP server might be impossible for some who cannot modify this information, but an option wopuld be just use your NAS as the DHCP server. I think people would appreciate this APP if it ever gets made.
Thanks for your input StephenB.
David
15 simultaneous Acronis backups certainly can benefit from bonding.
howarddavidp wrote:
...I have always wished there was an Acronis app for ReadyNAS where I could PXE boot into the device and load Acronis for restores when I have a drive fail (via booting over TFTP to an ISO file stored on my NAS).
This sounds like a good candidate for the ideas exchange. Maybe post it there.
