planetbob99
Aug 29, 2015Aspirant
How long does it take to expand a volume on a ReadyNAS 104
Hi, I have a ReadyNAS 104 that I had started using with just one disc in it, a WD Red 4TB. However as it was near capacity I got another WD Red 4TB to expand the volume onto. It did take a ...
- Aug 30, 2015
It seems awfully long to me, and normally RAIDar should be able to see it.
Aug 29, 2015Guru - Experienced User
Actually you'll need to have 3x4TB to get more capacity. 2x4TB just gets you redundancy.
What status are you seeing with RAIDar?
planetbob99
Raidar cannot find anything on my network. Though only used that after it went into this boot sequence. As did all previous configuring through the web interface.
