planetbob99
Aug 29, 2015Aspirant
How long does it take to expand a volume on a ReadyNAS 104
Hi, I have a ReadyNAS 104 that I had started using with just one disc in it, a WD Red 4TB. However as it was near capacity I got another WD Red 4TB to expand the volume onto. It did take a ...
- Aug 30, 2015
It seems awfully long to me, and normally RAIDar should be able to see it.
planetbob99
Also then is it possible to disable the redundency, I would prefer the space? As I use other things for back up. I really need this more for a networked storage than its actual redundency and can't afford a third drive for a while.
Aug 29, 2015Guru - Experienced User
You would need to switch to flexraid, destroy the volume, and then create two new ones (jbod).
One RAID-0 volume is possible, but is a bad idea (if either disk fails you lose all the data).
- planetbob99Aug 29, 2015Aspirant
Any idea though if it should be taking this long to boot back up? 48 hours for a total of 8TB of data (even if that is 4TB redundant) seems an awful long time.
- StephenBAug 30, 2015Guru - Experienced User
- planetbob99Aug 30, 2015Aspirant
Thanks, did a forced reboot and now it is back up. Currently balancing, and I can see it on the network again.
Though as you said earlier it is redundant and not more space. I may wipe it and set up as Raid 0, I understand the risks with that.
