Visionoz
Jun 06, 2018Aspirant
How long should ReadyNas NV+ take to be ready when "Factory Default Settings"
Recently the ReadyNas NV+ unit with 4 x 500GB hdds went into "Booting..." after a power outage without actually booting.
I decided to do a reset Factory Default Settings after my attempts at "...
- Jun 23, 2018
StephenB wrote:
Visionoz wrote:
Upon checking the LED documentation it seems apparent the PSU might be the culprit.
Something definitely is wrong, but I'm not seeing how you are reaching that particular conclusion.
Can you explain?
By elimination process that was the only plausible reason for the condition...
Visionoz wrote:
Please confirm that there are no other steps that I could try.
You could try doing a factory reset with only one disk installed. That would reduce the load on the PSU, so if it is marginal it might tell you something.
TQ StephenB - Please accept my apologies for this belated post/response as I had to travel overseas on a job assignment at short notice hence was unable to get back to this until 2 weeks ago.
I tried the single disk and all worked well - thereafter I redid the process with 2 disks at once and kept on adding back each harddisk one at a time and when all 4 were running and all seems to have worked for the next 3 days I shut down and started looking for a replacement PSU and was even willing to use a used one.
I was very lucky in being able to obtain a brand new replacement PSU from eBay and since then the unit has been refurbished and back in service again. I wasn't taking any chances so decided I might as well replace the PSU.
Thankyou for your guidance and directions without which I would not have been able to resolve the issue successfully!
Cheers
Bill
Jun 08, 2018Guru - Experienced User
Can you explain?
Visionoz
Jun 23, 2018Aspirant
Can you explain?
Cheers
Bill
