JovannB
Jun 23, 2017Tutor
How many concurrent FTP-Connections possible
Hi, I want to use my NAS for Backup purpose of up to 10 clients, therefore I want to use FTP transfering data to NAS - in times of wanacry and co one shouldnt use SMB which would be easier but mu...
Hopchen
Jun 23, 2017Prodigy
Hi,
What model NAS do you have?
JovannB
Jun 23, 2017Tutor
Hi,
as written in the footer: RN31443D
J.B.
- HopchenJun 23, 2017Prodigy
Ahh didn't see :)
Firstly, you can technically have as many concurrent FTP connections as you want. Of course if 10 computers are writing data to the NAS at the same time, things will slow down.
Just a note about WannaCry. It's a vulnerability in Windows SMB, not in the Linux (NAS) implementation. Secondly, it affects only SMB v1 which you shouldn't use anyway. Just use SMB v2 or v3 and you will be fine. Any newer Windows version uses SMB v3 anyway. You can even force the NAS to only accept SMB v2/v3 connections via the SMB Plus add-on.
But this of course your choice. If are set on FTP then make sure you use FTP(S) if going over the internet.
Cheers
- StephenBJun 23, 2017Guru - Experienced User
FTP has had it's own CVEs, they just haven't gotten the press.
If you want to use FTP for local backup, I suggest using a backup utility on the PCs for that (instead of NAS backup jobs). It'd be best to force FTPS in the NAS configuration.
On scale, it should handle 10 connections, though it might be best if you stagger the backup schedule.
