CesarR's avatar
CesarR
Follower
Sep 23, 2015
VPN Max Concurrent clients
Hello
I am looking in the web site a firewall / router solution that give me at least 200 SSL VPN concurrent connections but i dont seem to find it. Any advice?
Thanks
  • Hi CesarR,
    Welcome to the community!
    I can see you are looking for a router/firewall that can support 200 concurrent SSL-VPN connections. For our routers/firewall models the highest we have is only 75 (UTM150 - will be EOL in 2017), second highest one that we have is the SRX5308 which has 50 concurrent SSL-VPN connections only. As of the moment, we no dot have a router/firewall that supports  200 concurrent SSL-VPN sessions.
    If you have more questions, I'll be happy to assist.
    Thanks,
1 Reply
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hi CesarR,
    Thanks,
ProSupport for Business
