ulfrickardsson
Aug 26, 2012Aspirant
How to backaup NAS
New to this... I have an Readynas duo v2 with 2 1Tb hardrives. Modell: ReadyNAS Duo [X-RAID] Fast programvara: RAIDiator 4.1.9 [1.00a043] Minne: 256 MB [2.5-3-3-7] Volym C: Online, X-R...
vandermerwe
Aug 26, 2012Master
It is possible to do it this way, but not recommended.
The drives are not designed to be removed an reinserted as frequently as this.
You are better off using the RAID protection against drive failure and using an external drive as your backup - put your extra drive into a cheap enclosure and use this to do regular scheduled backups via USB.
