h_tsopelas
Aug 03, 2015Aspirant
How to backup from remote to local
Hello again... i want to back up my main folder with my files from Remote to a folder which i have create to the local. I try to do this but when i select remote it wants to fill: Host Protocol S...
- Aug 04, 2015
It ok now... my fault was that i do not share the folder which i want to take the backup. I do it with the first protocol!
Sandshark
Aug 03, 2015Sensei
h_tsopelas wrote:Hello again...
Host
Protocol
Share
Login
Password
I have linux (Ubuntu), how i fill these lines so i take backup my files? Also if a file from the remote is the same file to the local it replace it automatic or it will ask me? Thanks you and sorry for my bad English...
Host is the IP address of the remote system. Protocol depends on your preference, but Rsync is usually best when working with Linux on both ends. Share is the full path of what you want backed up (without a leading "/"). For Rsync, you may or may not need a password, it depends on how you set up the remote Rsunc server.. For others or Rsync with password required, you do; and it must be a valid user name and password for that remote system. Be aware that any firewall on the remote side may need to be set up to allow your NAS to "pull" data from that system. If you don't have control of that, then do it the other way and have the remote system "push" data to the NAS.
Use the "Check connection" button to be sure you have it right.
Yes, all files with the same name and path will be overwritten with no warning. When using Rsync, you also have the option on the Advanced page to have anything deleted on the remote system to be deleted on the NAS.
h_tsopelas
Sorry but i am new user, how i can find local ip for my linux ubuntu?
- StephenBAug 03, 2015Guru - Experienced User
# hostname -I
from the ubuntu system's command line.
- h_tsopelasAug 03, 2015Aspirant
Host: the ip from hostname -I
Protocol: Rsync Server
Share: /home/liakos/Desktop/ARXEIA
Username:
Password:
The share folder is the folder which i want to take the files.
It gives me error Unable to connect to host Code: 7077010011
- SandsharkAug 03, 2015Sensei
One of serveral possibilities:
First is that you included the leading "/" in the share name, which I said not to do. So try without it. Next, have you enabled Rsync read/write on the NAS share (but I thnk it doesn't give you that option in Backup if you don't)? Next, have you set up Rsync services on the remote system? Fourth, have you set it up without a password being required (note that Rsync user and password do not have to be the same as a standard user and password)? Fifth, have you limited the systems that can connect to it? Last, is there a firewall you have to deal with?
Try using NFS and Windows Timestamp protocols (with an appropriate user name and password) and see if that works. If it does, it cuts down on which may be the problem.
One of the Admins or Netgear support may be able to help with the decoding of the error code. I'm just another user and don't have the "magic decoder ring".
